slappetito
#1 Posted : Sunday, May 17, 2009 1:30:42 PM(UTC)
slappetito
I opened the door after a complete wash cycle only to find that some of the clothes were dry and some were wet. I don’t think the drum ever rotated during the entire wash.
Upon examination, the belt is properly connecting the motor and drum. I can manually spin the drum and when I do both the belt and the shaft on the motor spin. The smaller motor that drains water from the drum works fine.
I suspect that it is the motor but wanted to confirm it before ordering given the return policy on motors. Is there an easy way to confirm my assumption about the motor?
Thanks for any assistance.
#2 Posted : Sunday, May 17, 2009 3:45:46 PM(UTC)
Have you watched the washer during the spin cycle?
penngator
#3 Posted : Sunday, May 17, 2009 4:04:19 PM(UTC)
penngator
hey gene............if you please could ya help me with a problem???
our whirlpool washer will NOT rotate........it makes a clicking noise when it runs in the spin cycle,,,,,,the pump is still working tho............it WILLNOT spin!!!!! thoughts????
thanks
#4 Posted : Sunday, May 17, 2009 4:06:38 PM(UTC)
thanks
What is the complete model number of the washer?
slappetito
#5 Posted : Tuesday, May 19, 2009 10:07:16 AM(UTC)
slappetito
Yes, the water flows into the drum, the drum does not turn, and the water pump pumps the water out of the machine. You never hear the main motor turn on.
#6 Posted : Tuesday, May 19, 2009 12:56:44 PM(UTC)
Remove the front bottom access panel and look for an envelope with the tech sheets. Perform the troubleshooting as instructed in the tech sheets and post the results.
Guest (6)
