baileykraus
#1 Posted : 16 years ago
baileykraus
The water is not draining from the unit after each wash. I have to manually drain using the small tube or the pump drain.
I have taken the unit apart and cleaned any junk out of the hoses and pump area but this still did not resolve the issue.
When I try the drain option on the unit it still does not drain all the water from the unit. The pump on the bottom of the unit seems to be working.
I also checking the leveling of the unit and this is fine.
Any ideas on how to fix this? Do I need a new pump?
BK
sidfink43
#2 Posted : 16 years ago
sidfink43
Sorry no one has gotten back to you, but your machine is not one many tech's have worked on, including myself.
That said, based on your description of your problem, and the fact that you are certain there is no blockage in your water discharge system, I would try replacing the pump. No guarantees, but it is not an expensive part and if nothing else it will rule out the pump as a problem.
Here is your part.
WFL2060 UC/01 (FD 8111-)
Good luck and let us know how it turns out.
baileykraus
#3 Posted : 16 years ago
baileykraus
Great I picked the one device you don't have experience with! I order the part already this weekend. Is there any method of getting a repair manual for this machine? (not the owners manual).
BK
sidfink43
#4 Posted : 16 years ago
sidfink43
Sorry to disappoint you again, but I cannot find a service manual for your model. I would suggest you contact Bosch and see if you cannot get one from them.
Replacing the pump should not be difficult, since you already know how to get to that area of the machine. When you take the connections off you should expect some water to gush out, so be prepared.
Bosch Axxis washer does not start, 2 lights flash (Washer Repair)
by mabmab 12 years ago
Bosch axxis washer "water tap closed" error (Washer Repair)
by jstew0903 14 years ago
bosch axxis washer motor (Washer Repair)
by vsparrow01 15 years ago
