rocketscientistne
#1 Posted : 10 years ago
rocketscientistne
I have a Whirlpool LE5800XSW0 over 20 years old but working well. The heating element failed; I verified this by testing continuity of the fuses, thermostats, and element; all were good except the element.
My problem is that the unit has a single piece box for the heating element and I can't get the thing out of the dryer. Are there any other screws than the top mounting screw? I believe I have everything disconnected but the box won't budge. I cannot visually locate any other fasteners. Before I take a rubber hammer or anything stronger to it I'd like to find out if I am missing anything.
Thanks!
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
Parts manual shows one other screw at the bottom of the heater box.
http://shared.whirlpoolc...%20List%20-%20696487.pdf
Eric
rocketscientistne
#3 Posted : 10 years ago
rocketscientistne
Thanks. I believe that is the screw that holds the heating element to the heater box; I removed it and the element is free; however I cannot get enough clearance to pull the element out of the box without removing the box. I haven't found any other fasteners.
