repchino
#1 Posted : Saturday, May 9, 2015 7:39:55 PM(UTC)
repchino
I'll try to explain. One day my washer fill out of water, the next day it don't work on NORMAL cycle. I move the knob over all and the washer don't response, just on PP cycle and I have to find a point for "start". I changed the timer and nothing, I changed the water valve and nothing. There's a chance that timer comes bad? Or the problem could be other thing?:confused:
sidfink43
#2 Posted : Sunday, May 10, 2015 3:47:20 PM(UTC)
sidfink43
This really sounds like a timer issue, but it is unlikely you got a bad one. So I think the more likely problem is one with the connectors of the wire harness to the timer. Check them and see if there is a burned spot or a problem.
repchino
#3 Posted : Sunday, May 10, 2015 5:26:43 PM(UTC)
repchino
Thanks sidfink43, I check the conector and is good, actually it fit firmily that on the old timer.I was think on the level switch. Now when I put on NORMAL cycle it star to fill and I active the level switch blow it, but the washer not agitade.
