jbax2004
#1 Posted : Friday, May 8, 2015 9:09:55 AM(UTC)
jbax2004
Hi, my name is James. I am having some issues with my whirlpool dishwasher. After my wife complained of dishes not being cleaned I started checking it out to see if I could trouble shoot it. I first noticed that the unit would fill to right about element level (held door shutoff switch to see what was happening), the pump would start for a fraction of a second then stop and start to drain. The unit would then fill again and start to wash, but the pressure was so low that the lower arm would barely spin and no water would reach the upper arm (supply tube was clean). The motor seemed to be spinning fine. I took all removable parts from the tub(filter, impellers, checkballs, drain check, hoses, etc.)and thoroughly cleaned them, and replaced the impeller because it was chipped. I also ran a cycle with the pressure switch un plugged (per a suggestion on a different tread I read)after doing so, the unit did not drain after the initial fill, but the water pressure was still very low. At this point, we are tired of hands washing dishes, and would appreciate any advice or suggestions!
Jeff / APP Team
#2 Posted : Friday, May 8, 2015 9:25:41 AM(UTC)
Jeff / APP Team
Make sure the spray arms are not clogged on the holes and the filters are clean. If so, and the impeller is new, you will need to replace the motor in the unit. Part number: AP3604401
jbax2004
#3 Posted : Friday, May 8, 2015 10:24:50 AM(UTC)
jbax2004
Will installing the new motor also correct the issue of immediately draining after filling, or will the pressure switch also need changed out?
Jeff / APP Team
#4 Posted : Friday, May 8, 2015 10:36:20 AM(UTC)
Jeff / APP Team
According to the tech sheet, that is a program of the board.
