Our Whirlpool washer makes a humming noise and will not drain. What could be causing this?
An article of clothing is stuck in the PUMP!!!
This washer has a drain pump with it's own motor.
I would venture a guess that something got in the pump and is jamming the impeller causing the motor to hum.
I am not used to the model you posted.. But I know the only way to know if there is something in the pump is to take the hoses off and see for yourself.
