egizzi
#1 Posted : Friday, April 24, 2015 9:52:38 PM(UTC)
egizzi
The stovetop (gas) is fine.
The oven all of a sudden seems to heat very very slowly. Also the display seems dim as well.
I've powered it off/on at the circuit breaker.
What next?
egizzi
#2 Posted : Saturday, April 25, 2015 7:48:35 AM(UTC)
egizzi
The oven is electric.
Update from this morning.... the broiler seems to work. The bake and convection don't do anything.
egizzi
#3 Posted : Saturday, May 2, 2015 7:34:50 AM(UTC)
egizzi
I replaced the bake element. Same problem. The bake element does not even get hot to touch. The broiler is on though.
My daughter said that she remembers the elements turning red when being used. If that's the case, the broiler, even when set on high, is not turning red.
What next?
#4 Posted : Sunday, May 3, 2015 12:39:24 AM(UTC)
[COLOR="Blue"]If that's the case, the broiler, even when set on high, is not turning red.[/COLOR]
I am not sure I understand the above as in an earlier post you said it was working.
On most ovens they do switch back and forth between the bake and broil elements during preheat and bake cycles. This gives a more even temperature profile in the oven.
Since you mentioned a dim display I would check the power with a meter so it can be eliminated as a possible cause.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Oven Heats Very Slowly (Dryer Repair)
by wyroper 10/21/2009 6:42:59 AM(UTC)
Oven heats very slowly (Oven Repair (including Ranges and Cooktops))
by GSHOBBICK 4/29/2009 3:50:32 AM(UTC)
