water leaking on the flood and in the frig. I defrosted the drain and no water leaking for the past few days, I shut the icemaker off. is there a adjustment for the water flow to the icemaker? what caused the drain to freeze up?
water leaking in the frig and on the floor. I defrosted the drain in the freezer and on leaks for three days. what caused the drain to freeze?
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
