JM Selkirk
#1 Posted : Saturday, April 4, 2015 5:26:21 PM(UTC)
JM Selkirk
Washer will not advance past wash/drain/spin cycle, into the rinse phase.
Have replaced timer. No go.
fairbank56
#2 Posted : Saturday, April 4, 2015 5:38:44 PM(UTC)
fairbank56
Groups: Expert
Must have the model number in order to help you.
Eric
JM Selkirk
#3 Posted : Sunday, April 5, 2015 11:13:21 AM(UTC)
JM Selkirk
Eric
Model number keeps coming up as refridgerator
JM Selkirk
#4 Posted : Monday, April 6, 2015 3:51:47 PM(UTC)
JM Selkirk
Eric
Model # is LSQ9200LQ3
fairbank56
#5 Posted : Monday, April 6, 2015 6:02:41 PM(UTC)
fairbank56
Groups: Expert
So, your saying it will fill, agitate, drain and spin but will not start filling again for the rinse cycle? What water temp setting are you using?
Eric
JM Selkirk
#6 Posted : Tuesday, April 7, 2015 10:27:44 AM(UTC)
JM Selkirk
Eric
Warm,mostly, but also occurs on all temps.
fairbank56
#7 Posted : Tuesday, April 7, 2015 11:41:54 AM(UTC)
fairbank56
Groups: Expert
So, if temp is set to cold/cold, it will fill with cold water in the wash cycle but will not fill at all in the rinse cycle? It's sounding like cold water is not working. Rinse fill is cold only, even if temp is set to warm/warm, the only warm water during rinse is the spray during the spin cycle. If you get cold water ok during wash fill but not rinse, then you need to check continuity of the yellow/red wire that runs from the timer to the temp switch and to the cold water valve solenoid.
Eric
Guest (8)
whirlpool washer repair (Washer Repair)
by bristol6811 4/29/2013 6:09:14 PM(UTC)
whirlpool washer REPAIRS (Washer Repair)
by djprall 7/14/2011 2:48:09 PM(UTC)
Whirlpool washer repair manual (Washer Repair)
by mo723 6/4/2009 5:37:45 PM(UTC)
