Washer will not advance past wash/drain/spin cycle, into the rinse phase. Have replaced timer. No go.
Groups: Expert
Must have the model number in order to help you.
Eric
Originally Posted by: fairbank56 Must have the model number in order to help you.
Eric Model number keeps coming up as refridgerator
Eric Model # is LSQ9200LQ3
Groups: Expert
So, your saying it will fill, agitate, drain and spin but will not start filling again for the rinse cycle? What water temp setting are you using?
Eric
Originally Posted by: fairbank56 So, your saying it will fill, agitate, drain and spin but will not start filling again for the rinse cycle? What water temp setting are you using?
Eric Warm,mostly, but also occurs on all temps.
Groups: Expert
So, if temp is set to cold/cold, it will fill with cold water in the wash cycle but will not fill at all in the rinse cycle? It's sounding like cold water is not working. Rinse fill is cold only, even if temp is set to warm/warm, the only warm water during rinse is the spray during the spin cycle. If you get cold water ok during wash fill but not rinse, then you need to check continuity of the yellow/red wire that runs from the timer to the temp switch and to the cold water valve solenoid.
Eric
