morgan6107
#1 Posted : Friday, April 3, 2015 9:41:48 AM(UTC)
morgan6107
My dryer recently began starting, running for 10-15 seconds, stopping, then repeating the process over and over. It does all of this while saying it is in the sensing mode. I had a repairman come out and tell me it was the electronic control board that needed to be replaced. I replaced it yesterday, part# W10405827, and it is still doing the same thing.
fairbank56
#2 Posted : Friday, April 3, 2015 10:33:18 AM(UTC)
fairbank56
Groups: Expert
Does it do this in the timed dry cycle or only in auto dry cycle?
Eric
morgan6107
#3 Posted : Friday, April 3, 2015 10:38:35 AM(UTC)
morgan6107
It does it in the timed dry cycle also.
fairbank56
#4 Posted : Friday, April 3, 2015 11:38:27 AM(UTC)
fairbank56
Groups: Expert
Then you would have to do some electrical troubleshooting to determine if your losing voltage to the motor or if the motor thermal overload is tripping. This is likely beyond your capability and a little too difficult for me to try and explain the process for you over this forum.
Eric
