2 Pages<12
#11 Posted : Sunday, March 22, 2015 2:20:48 PM(UTC)
You are getting heat so the centrifugal mechanism that actuates the switches is probably working correctly.
It is more like;y to be the board.
allwet
#12 Posted : Monday, March 23, 2015 7:40:43 AM(UTC)
allwet
OK thanks denman, I will further in to the control board, I am going to check if I can get it locally as I am in Canada. I will also be looking at simply replacing the relay that affects this operation, Omron relays are generally reasonably priced...
2 Pages<12
