Arnaud
#1 Posted : Saturday, September 6, 2014 7:00:38 PM(UTC)
Arnaud
Hello,
The only button that lights up is "Locked hold to lock".
From there the machine won't do anything.
Won't start a cycle.
Question is that a Latch or a control panel (Mother board) problem?
Thanks you,
-A
#2 Posted : Sunday, September 7, 2014 1:35:21 AM(UTC)
Parts for Maytag MDB7609AWS2 Dishwasher - AppliancePartsPros.com
Note that lock does not refer to the door lock.
It is a software keypad lock.
Have you tried unlocking it. see below.
Control Lock
To avoid unintended use of your dishwasher, or cycle and option changes during a cycle.
To turn on Lock, press and hold Heated Dry for at least 3 seconds.
To turn off Lock, press and hold Heated Dry for at least 3 seconds.
When Control Lock is lit, all buttons are disabled. If you press any pad while your dishwasher is locked, the light flashes 5 times. The dishwasher door can be opened while the controls are locked.
If the above does nothing then try removing power from the unit for a few minutes to see if the computer will reset.
If neither of the above does anything then I will have to try and find a tech sheet so you can check the keypad.
The problem will either be the control board or the keypad.
Arnaud
#3 Posted : Sunday, September 7, 2014 4:01:59 AM(UTC)
Arnaud
Hello Denman,
Thank you for taking time reading and answering my question.
I shut the power off for more than 20 seconds and restart the machine.
Still the Lock light remained ON.
I also pressed it for 5 seconds, and nothing flashed and dishwasher door is still open-able.
It just happened once after my twentieth attempt that the Wash light went ON. Some noise like engine/water running wanted to comes, but after 30 seconds, it stopped. NO traces of water inside. And the light "Lock" stayed ON.
Does this last observation help for a diagnostic?
Does it confirm an issue with the KeyPad lock.
best wishes,
-A
#4 Posted : Sunday, September 7, 2014 4:38:00 AM(UTC)
The tech sheet is too large to attach here so I had to use a 3rd party site, see below.
Unclick the use our download manager and then use the grey button to download it. Otherwise the site may put software on your computer that you do not want.
Download MDB7609.pdf
[COLOR="Blue"]
Does this last observation help for a diagnostic?[/COLOR]
It does sort of pint to the control board but I cannot say how strongly it points to it.
Yes there is a problem with it.
It will be the control board or the control panel/keypad.
The normal way to troubleshoot is to check the key outputs from the control panel and then if it is OK replace the control board.
Still a bit of a crap shoot but your odds are better.
The tech sheet has info on how to check key switches.
Since the Heated Dry switch is the active key that is the most important one you want to check.
It may be that it is always closed.
Arnaud
#5 Posted : Monday, February 23, 2015 4:54:49 AM(UTC)
Arnaud
Hello Denman,
I am having an issue again with my Maytag dishwasher.
In September, I changed the front panel and it was fine.
All the lights indicators went on and the machine run smoothly.
Five months after, I observed the same problem.
No more lights on the panel, machine not working.
I dismantled the panel and reassembled it again, it worked for one week.
Died after.
Do you think it the mother board the problem?
Thank you,
Arnaud
#6 Posted : Tuesday, February 24, 2015 1:35:41 AM(UTC)
ASince the control panel is relatively new it does point towards the control board.
Perhaps try removing power from it for a few minutes to see if it will reset.
Either unplug it or flip the breaker off.
If it does reset this also points to a control board problem.
Arnaud
#7 Posted : Thursday, February 26, 2015 2:51:32 PM(UTC)
Arnaud
Hello Denman,
What would you suggest next?
A new panel with a new motherboard were re-installed.
Unlike the first time, nothing happened. Is there is another part you would recommend me to try to change before I give up?
Best,
arnaud
#8 Posted : Friday, February 27, 2015 12:40:43 AM(UTC)
Have you checked the door switches and the thermal fuse?
Arnaud
#9 Posted : Sunday, March 8, 2015 7:18:30 PM(UTC)
Arnaud
Hello Denman,
I haven't check yet the thermal fuse nor the door switches, but I noticed that the detergent dispenser small door got jammed. The lock of the dispenser got glue or fused with the dispenser. Therefore it cannot be closed.
Is there is some kind of senser that would prevent the machine to run in that condition?
Is there is a device that could be plug to the machine and tell you what is wrong? This instead of guessing which part is defective?
Best,
Arnaud
WeAreNotAlone
#10 Posted : Monday, September 12, 2016 8:53:16 PM(UTC)
WeAreNotAlone
Originally Posted by: Arnaud Go to Quoted Post
Hello Denman,
Best,
Arnaud
Arnaud,
Where you able to fix your Maytag MDB7609AWS2 Dishwasher?
What was the problem? (In as much detail as possible.)
Guest (4)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
