rmichelotti
#1 Posted : Friday, May 15, 2009 10:03:57 AM(UTC)
rmichelotti
I am looking for a repair part fot my older refrigerator. Does anyone know if there is a part cross reference to another mfg. part, or where I might still find one?
Part description:
Freezer defrost element (element within a glass tube). Unit is freezing up.
RLM
#2 Posted : Friday, May 15, 2009 12:00:11 PM(UTC)
Here is a link
Model Search
Give them a call or an email
Are you sure that the defrost element is blown.
Best to check it with a meter.
It could also be the defrost timer or the defrost element.
Though the glass type heaters do go fairly often and often yo can see where they have burned out.
I will also send your post to AppliancePartsPro's, the people who sponsor this site
#3 Posted : Friday, May 15, 2009 6:55:17 PM(UTC)
If you sure the problem is a bad defrost heater then post a pictures of it and measure the size. Is it a single or a double heater? Also look for a part number on the heater.
Adam / APP Team
#4 Posted : Monday, May 18, 2009 8:11:32 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear rmichelotti,
Due to the age we will need to have our research department look it up on microfich.
However we will need the manufacturer number/BM number. It will be located on the same tag as the model and serial consisting in 5 number and letter combinations.
