Machine had stopped working in the middle of a wash cycle. No power at all. CCU needed to be repaired. I removed the front kick panel to be able to unlock the door(get cloths out) and found in the back was a green service manual with how-to fix certain codes and how to remove the CCU. It was very easy to remove once I read the manual. I labeled the wires so I new which ones went on top, side and other side. Easy to reconnect them as they only go in their slot and no others.
Good job, and thanks for sharing the experience with everyone.
