2 Pages12>
Kestryll
#1 Posted : Wednesday, November 13, 2013 3:43:27 PM(UTC)
Kestryll
So i have the front load Frigidaire front load washing machine. It will not spin at all. I replaced the front door lock motor thingy as I was told it could be part of the problem, since I could open the door at any time during the cycle. I have replaced that and installed a new motor and I still cannot get the machine to spin. Please help.
Appliance Ninja
#2 Posted : Wednesday, November 13, 2013 3:45:57 PM(UTC)
Appliance Ninja
Will the machine tumble back and forth? Does it pump the water out even though it does not spin?
Kestryll
#3 Posted : Wednesday, November 13, 2013 4:06:52 PM(UTC)
Kestryll
no tumbling whatsoever. Yes it will pump water out. If it pumps everything out, I have no idea.
Appliance Ninja
#4 Posted : Wednesday, November 13, 2013 4:28:46 PM(UTC)
Appliance Ninja
Thank you! The motor controller is mounted on the base of the machine, under the tub. Can you get a look at that electronic control for any visible damage or burn marks? Also, there is a fuse on that board. Do you have a meter to test it with?
Kestryll
#5 Posted : Wednesday, November 13, 2013 4:43:34 PM(UTC)
Kestryll
No visible damage or burn marks. I have a cheap volt meter somewhere. How would I test this.
Appliance Ninja
#6 Posted : Wednesday, November 13, 2013 4:58:22 PM(UTC)
Appliance Ninja
There should be a setting labeled Rx1, when the probes are touched together, the needle should move. A probe on each side of the fuse should also make the needle move. Does it?
Kestryll
#7 Posted : Wednesday, November 13, 2013 5:29:52 PM(UTC)
Kestryll
I'm looking at the diagram and the box and do not see rx1. Is this there the connected plug goes into the control?
Appliance Ninja
#8 Posted : Wednesday, November 13, 2013 5:38:06 PM(UTC)
Appliance Ninja
The Rx1 will be on your meter, you asked how to use it to test the fuse..... ;-)
Kestryll
#9 Posted : Wednesday, November 13, 2013 5:45:18 PM(UTC)
Kestryll
Silly me. I'm looking at the circuit board and seeing r14 and became confused.
UserPostedImage
I'm using this volt meter.
Appliance Ninja
#10 Posted : Wednesday, November 13, 2013 5:50:54 PM(UTC)
Appliance Ninja
The picture did not come through, sorry. The setting will be marked Rx1 or have a horseshoe looking symbol. When the probes are touched together, the needle should move.
2 Pages12>
