AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Wont spin at all, replaced motor too!
So i have the front load Frigidaire front load washing machine. It will not spin at all. I replaced the front door lock motor thingy as I was told it could be part of the problem, since I could open the door at any time during the cycle. I have replaced that and installed a new motor and I still cannot get the machine to spin. Please help.
Will the machine tumble back and forth? Does it pump the water out even though it does not spin?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Will the machine tumble back and forth? Does it pump the water out even though it does not spin? no tumbling whatsoever. Yes it will pump water out. If it pumps everything out, I have no idea.
Thank you! The motor controller is mounted on the base of the machine, under the tub. Can you get a look at that electronic control for any visible damage or burn marks? Also, there is a fuse on that board. Do you have a meter to test it with?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you! The motor controller is mounted on the base of the machine, under the tub. Can you get a look at that electronic control for any visible damage or burn marks? Also, there is a fuse on that board. Do you have a meter to test it with? No visible damage or burn marks. I have a cheap volt meter somewhere. How would I test this.
There should be a setting labeled Rx1, when the probes are touched together, the needle should move. A probe on each side of the fuse should also make the needle move. Does it?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There should be a setting labeled Rx1, when the probes are touched together, the needle should move. A probe on each side of the fuse should also make the needle move. Does it? I'm looking at the diagram and the box and do not see rx1. Is this there the connected plug goes into the control?
The Rx1 will be on your meter, you asked how to use it to test the fuse..... ;-)
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The Rx1 will be on your meter, you asked how to use it to test the fuse..... ;-) Silly me. I'm looking at the circuit board and seeing r14 and became confused. ![UserPostedImage](http://www.7corners.com/catalog/images/GDT-3190.jpg) I'm using this volt meter.
The picture did not come through, sorry. The setting will be marked Rx1 or have a horseshoe looking symbol. When the probes are touched together, the needle should move.
Washer Repair
