AnthonyJS02
#1 Posted : Saturday, January 10, 2015 9:12:07 AM(UTC)
AnthonyJS02
Hello all stumbled upon this website while trying to figure out why my dishwasher won't drain all way. I have checked drain hose to garbage disposal and have used shop vac to end of hose and sucked out any debris. I have disassembled the sprayer, lock cap(broke the locking tabs) took off filter, unlocked upper sprayer arm and only found little mush in back drain. But still no luck. What would be next step?
#2 Posted : Sunday, January 11, 2015 1:19:46 AM(UTC)
Parts for GE GLD5850L15CS Dishwasher - AppliancePartsPros.com
You could undo the drain hose at the disposal and get it to drain onto a pail.
Hold the hose securely in the pail and put a towel etc. over it to stop water splashing all over. This will eleiminate the drain as a possible cause.
If it is still a problem.
You will have to work your way back from the main pump to be sure the drain is clear.
Pay special attention to the flapper valves (items 328 in section 05).
Probably i is best to pull the dishwasher out from the cabinet.
Also check the sump fo any sign of rot. They can develop a crumbly coating on the inside which is the rubber breaking down. If there is any replace the sump as it is a leak waiting to happen.
AnthonyJS02
#3 Posted : Sunday, January 11, 2015 4:25:19 AM(UTC)
AnthonyJS02
Thanks for response. Is it pretty easy task pulling the dishwasher out?
#4 Posted : Sunday, January 11, 2015 10:25:43 AM(UTC)
Depends how it was installed.
Go to the GE appliance website you should be able to find the install sheet.
Guest (6)
