Originally Posted by: rjneill  I also have a simuliar question on these parts #23. How tight do you tighten the impeller assembly to the motor? Also parts #22, 23, 30 how do they go together. How does both rubber rings (23) seat together, rubber against rubber or the metal washer against rubber? Thanks
