rjneill
#1 Posted : Monday, May 4, 2009 3:36:48 PM(UTC)
rjneill
replacing the seal kit on the impeller. Part #23 is a washer with rubber on one side and the metal on the other. Which side goes toward the impeller and also which type of grease and amount?
http://www.appliancepartspros.c...98&diagram_id=954610
BRYAN777
#2 Posted : Thursday, May 14, 2009 10:36:23 AM(UTC)
BRYAN777
I also have a simuliar question on these parts #23. How tight do you tighten the impeller assembly to the motor? Also parts #22, 23, 30 how do they go together. How does both rubber rings (23) seat together, rubber against rubber or the metal washer against rubber?
