rickric
#1 Posted : Monday, August 27, 2012 4:16:55 PM(UTC)
rickric
Rank:: Member
The gas oven / broiler won't light on my Amana. If I hit the gas valve they will lite. I understand that the broiler and the oven burners each have their own bi metal valves within the gas valve, what I don't understand is how both would be bad. I have checked the conections.
Thanks for any help
Simon / APP Team
#2 Posted : Tuesday, August 28, 2012 12:57:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will need the amp meter to check the current draw of the each ignitor. The 3.2Amp is minimum for normal work. If it's less - replace the ignitors.
The bake ignitor Part number: 31940001
The broil ignitor Part number: 786324
Part number: 786324
You will have to reuse the old brackets, so be very careful not to brake the grey portion of the ignitors - very fragile.
Good luck and post the results.
Simon.
rickric
#3 Posted : Tuesday, August 28, 2012 4:40:21 PM(UTC)
rickric
Rank:: Member
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Part number: 786324
Simon.
Simon,
Thanks for the advice, would both go at the same time? they both glow bright red, and why would they light the burner when I hit the Gas Valve?
Rick
terrabill
#4 Posted : Thursday, January 1, 2015 3:00:01 PM(UTC)
terrabill
Hi Rick,
Hoping the site emails you when someone posts a reply.
Can you tell me what fixed the issue with your Amana bake and broil functions not working back in 2012? I have the same situation and I see Simon never replied as to why both igniters would fail at the same time. I was suspecting the $1xx valve vs the $2xx control board.
Thanks much.
rickric
#5 Posted : Monday, January 5, 2015 4:32:37 PM(UTC)
rickric
Rank:: Member
Terrabill,
To be honest I haven't repaired it yet, it's at a vacation home and I have been just tapping on the gas valve to light the oven. I'm going to by an igniter for the bake and try it when I get back in the spring.
Good luck and if you find out anything please let me know
