justin r
#1 Posted : Wednesday, December 31, 2014 12:32:12 PM(UTC)
justin r
Yesterday i found the washer sitting full of water to the point where it had poured out on the floor. Unit was off. So I drained the washer and turned it off. Today when i got home from work the washer was full of water again, with water all over the floor, unit was off. The strangest thing I have even seen... What is going on? Gremlins maybe? lol.
sidfink43
#2 Posted : Thursday, January 1, 2015 5:29:36 AM(UTC)
sidfink43
Well I think you have three possibilities. One is that the water inlet valves are not shutting off completely and allowing water to fill the machine even after it is turned off. You should be able to determine if this is the case by inspecting the washer after it has run through a full cycle. The second cause could be a bad pressure switch and the third cause could be the main control board.
Inside the lower service panel are tech notes that will tell you how to generate error codes and test components.
justin r
#3 Posted : Thursday, January 1, 2015 5:41:16 AM(UTC)
justin r
thanks for your help, ill check the codes. :)
Guest (4)
