ericjesso1
#1 Posted : Tuesday, December 30, 2014 8:19:09 AM(UTC)
ericjesso1
stacked comb.o washer/dryer.everything works on washer but won't drain water out
sidfink43
#2 Posted : Tuesday, December 30, 2014 5:40:26 PM(UTC)
sidfink43
Okay, a lot of times on these models something washes over and blocks the drain hose from the tub. So take off the front panel and see if that is the problem, and check out the pump while you are at it.
If the drain lines are clear and the pump does not seem to have a problem operate it with the front panel off and see if you can determine what is happening.
This is a Frigidaire made machine for Sears Canada. Are you in Canada?
Need directions on how to remove machine lid (Washer Repair)
by lhughes48 11/21/2009 4:20:47 PM(UTC)
Need Directions On How To Replace A New Belt (Dryer Repair)
by caroline p 7/2/2008 6:35:46 PM(UTC)
