vettevxn
#1 Posted : 10 years ago
vettevxn
I have an Admiral side-by-side fridge that stopped cooling. The fan was still running but the compressor was clicking every 10-15 seconds & was trying to start. I read in another thread that a relay might fix the issue so I bought a new relay and installed it. The fridge started right up & ran for about 8 hours before it cut off and started clicking again. I also followed the continuity testing instructions in one of the posts & used a multimeter to test the compressor. I got 3, 4, and 7 as the results so I'm assuming that the compressor is okay. I can leave the fridge off for a day or so then plug it in and it'll work for 6-8 hours....then it just cuts off and starts clicking again. Is there something else I can test? I really appreciate any help you can offer!!
#2 Posted : 10 years ago
[COLOR="Blue"] I got 3, 4, and 7 as the results so I'm assuming that the compressor is okay.[/COLOR]
A winding test can tell you if a compressor is bad.
It does not tell you that the compressor is good as it may have other internal problems.
If the unit has a condenser/compressor fan check that it is on whenever the compressor is on.
If the compressor uses a capacitor you could try replacing it.
There is no good way to check a capacitor so it is a swap and see.
vettevxn
#3 Posted : 10 years ago
vettevxn
Thanks for the info! The fan beside the compressor is running when the compressor is on. There's a fan in the freezer that isn't running though. Also I repaced the capacitor when I replaced the relay overload.
Since the compressor runs for 8 hours or so then won't come back on, I'm stumped.
#4 Posted : 10 years ago
Check the fan in the freezer it should also be on when the compressor is on.
If it is getting 120 volts and not turning it is toast.
I am assuming that it is a AC fan and not a DC fan.
It is probably the cause of the unit running so long re: it is not pulling air through the evaporator coils so the unit is not cooling efficiently.
Perhaps this long run time is overeating the compressor causing your start problem.
