sonyusa
#1 Posted : Wednesday, December 24, 2014 8:48:18 AM(UTC)
sonyusa
RANGE TRANSIENT SUPPRESSOR blow out, i bought a use part and changed it
and after 20 minutes working perfect it fried out again.
any idea why??
thank you
#2 Posted : Wednesday, December 24, 2014 12:49:49 PM(UTC)
Parts for KitchenAid KEBC107KSS04 Oven - AppliancePartsPros.com
More info would help.
This is the second surge protector, correct?
Has this oven been at this location for some time or is it a new install?
Has any electrical work been done on the house?
Did you check the voltages with a meter?
What part on the protector blew?
File Attachment(s):
KEBC107.pdf (314kb) downloaded 5 time(s).
sonyusa
#3 Posted : Wednesday, December 24, 2014 9:34:20 PM(UTC)
sonyusa
Yes it is the second one, by mistake I blew out the one comes with the unit,
Oven is new but I did a bad connection to the 240 volts and blew it out, I got the replacement and installed it, aferter 20 minutes when the oven was working it blew out again.
I have 240 at the outlet.
#4 Posted : Thursday, December 25, 2014 5:26:59 AM(UTC)
What do you mean by a bad connection blew it out?
I am assuming that the connection worked Ok for the 20 minutes the oven was on.
I do not think that the oven could blow the suppressor so that is why checking the voltage is important.
Not only the 240 but also the two 120 volt sides (L1 and L2).
Also the ground and Neutral hook ups.
Note that 3 wire and 4 wire hook ups are different.
That info should be on the Whirlpool or KitchenAid site as part of the install sheet.
Note that the protector only protects the L1 side of the line and the Neutral as this is what powers the control board.
