spaldini101
#1 Posted : Friday, December 19, 2014 5:01:40 AM(UTC)
spaldini101
In a matter of a day or two, the frig temp. has gone from low 30's (a little too cold at times) to 45-50°, I haven't check freezer temp but it seems warmer too. Could it be the self-defrost timer ? It seems like it has done this in the past, but always kind of self-corrected before long.
- The compressor seems to cycle on and off normally. (i.e. doesn't run all the time)
- Fan blows cold air into freezer.
#2 Posted : Saturday, December 20, 2014 1:41:13 AM(UTC)
Parts for TBX21Z - AppliancePartsPros.com
The given model number seems to be missing several digits so you will have to choose a unit from the Matching Model Numbers section.
I doubt it is a dfrost problem. If it was the compressor would run all the time except when the unit goes thjrough a defrost cycle.
Since the unit is cycling I wouls say that the most likely culprit is the control thermostat.
spaldini101
#3 Posted : Saturday, December 20, 2014 4:31:01 AM(UTC)
spaldini101
Thanks Denman,
I have the thermostat to max. setting now "9", and coincidentally it did NOT kick on the compressor when I moved it there from "5". Does that also point to the stat?
Is there a way to test it before ordering a replacement? And are you referring to what they call the "Temp Control" ? $125 + or - ?? I may put that towards a new instead.
Freezer is holding at about 10°.
TBX21ZLJ
Is there a way to determine date of manufacture from the serial number? HA-586890
#4 Posted : Saturday, December 20, 2014 7:13:58 AM(UTC)
[COLOR="Blue"]I have the thermostat to max. setting now "9", and coincidentally it did NOT kick on the compressor when I moved it there from "5". Does that also point to the stat?[/COLOR]
Yes
[COLOR="Blue"]Is there a way to test it before ordering a replacement?[/COLOR]
I is already doing a test of sorts.
You said that the unit cycles correctly it is just doing that at the incorrect temperature so the only thing I can think of that would do this is the thermostat.
It would not hurt to remove the cover in the freezer and inspect the evaporator coils. They should have a fairly even coating of ice on them.
Also check that the fan is OK.
