CMANN1
#1 Posted : Thursday, August 28, 2014 6:08:58 PM(UTC)
CMANN1
Hi My name is Corey and this is my first post here,
Long story short, I bought a forclosure home and this oven was included and very clean so I would like to use it but I am having issues with the oven staying lit.
From the START this is what the sypthoms have been and work thats been done:
1.When "Preheating" oven Ignitor would glow, gas would light, and oven would start heating up. It would only stay lit for aprox 4-5 minutes then would go out with ignitor still glowing for a bit before it stopped glowing as well. The display would still read "Pre" as if is was still pre-heating. It seems to only heat up to 250 degrees F
2. I replaced the Ignitor with a new unit-----No Change
3. I replaced the Temp Probe with a new unit----No Change
The top 5 burners have no issues with staying on and the only other issue is that the lower RH burner doesn't ignite on its own but once lit it will stay on.
I am at a loss and need the oven to work. I do not have the funds for a whole new unit so if anyone has any ideas or suggestions I would be very greatful!
Thank you for taking the time to read.
Brand - Tappan
Model # TGF657BFW5
Age - 12yrs
JerryCaldwell
#2 Posted : Thursday, December 18, 2014 12:49:01 PM(UTC)
JerryCaldwell
I am having similar experience to what you describe. Were you able to solve the problem?
Like you I have replaced thermostat and ignitor, oven will not light.
thank you!!
CMANN1
#3 Posted : Thursday, December 18, 2014 1:00:06 PM(UTC)
CMANN1
Have not found a solution. We just do not use the preheat function. We use the bake function and it takes a long time to warm up. Good luck
Guest (4)
