Based on the information you posted looks like: - The part number for the upper oven thermostat is AP4101800
- The part number for the selector switch is AP4101316 - The part number for the Broil element is AP4283351 - The part number for the Bake element is AP4283357Gene.
Perfect! Many thanks Gene for your through answer to my post. What is my model number do you know?
I can not tell you exact model number of your oven, but I found a few very similar. One of them is 9844XPB.
Hi Gene : This Is Debora And You Mentions The Selector Switch Would Be Bad On My Double Over For Magic Chef And I Got A New One And When I Hooked It Up The Fan Went Out And The Ovens Wont Turn On Without Fan , Could It Be Any Other Thing Besides The Fan? I Do Know That When Ovens Are On The Fan Stays On At All Time Until I Turn Oven Off! Been That Way For 15 Years! THE FAN WORKED THE MINUTE I TURNED IT ONE BUT SUDDENLY WENT OUT! THANKS AGAIN GENE
Hi Debora,
Remove the oven from the cabinet and check for 240 VAC to the oven at the junction box behind the oven. Check all wires from the oven terminal block into the oven.
i changed every electric part in my oven and i found out the oven isnt getting 220 but the clock works so it only getting 110 what could this be , the breaker doesnt trip however ! please help me : debora g
ha gene , could you please tell me what the wiring schematic is for the magic chef 9522? i took the back of the oven apart and repaired any wire that was a possible short! is it possible the thermo block is bad? i did a volt check and on one side it didnt read and on the other i got a reading and spark because i must have touched wrong wire while taking it out! thanks gene, debora g
Hi Debora,
It can be a bad circuit breaker or a broken wires. It's impossible to visually diagnose circuit breaker. It has to checked for continuity. If you do not feel comfortable to work under power then it maybe better to call a certified electrician.
i was wondering if i put one wire on wrong maybe ! the oven is hard wired , no plug so should i still check there ? how possible is it that the breaker on one side is bad even though it doesnt trip outwardly?
