How do I replace the door/latch lock? I have the latch, but not sure how to get to the old one to replace it. Thanks!
Remove the BOOT SEAL near the latch, You should then be able to remove the latch mounting screws and the wires.:)
How do I remove the boot seal. :)
There is a wire and spring that hold it in place.(you have to look behind the front edge of it) It can be QUITE HARD to put this back on, If you need to call a PRO. If you feel brave, take a small screwdriver and pry the wire clamp off, the boot will then just peel away from the front panel.
THIS FORUM IS DEAD!!!!!!! |
