TMRAY
#1 Posted : Tuesday, May 12, 2009 12:52:27 PM(UTC)
TMRAY
How do I replace the door/latch lock? I have the latch, but not sure how to get to the old one to replace it. Thanks!
Drags1998
#2 Posted : Tuesday, May 12, 2009 2:58:42 PM(UTC)
Drags1998
Remove the BOOT SEAL near the latch, You should then be able to remove the latch mounting screws and the wires.:)
TMRAY
#3 Posted : Tuesday, May 12, 2009 5:41:51 PM(UTC)
TMRAY
How do I remove the boot seal. :)
Drags1998
#4 Posted : Wednesday, May 13, 2009 10:58:30 AM(UTC)
Drags1998
There is a wire and spring that hold it in place.(you have to look behind the front edge of it) It can be QUITE HARD to put this back on, If you need to call a PRO. If you feel brave, take a small screwdriver and pry the wire clamp off, the boot will then just peel away from the front panel.
#5 Posted : Wednesday, May 13, 2009 11:32:38 AM(UTC)
Replacement parts for WHIRLPOOL GHW9150PW0 | AppliancePartsPros.com
The breakdown may help locate things
Here is a service manual, does not specifically list your Model but hopefully will be close enough in this area of the machine to be useful.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Whirlpool Duet F06 error -- seeking input (Washer Repair)
by TexPat60 2/21/2022 8:25:46 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
