Our ice maker went out on the frigidare and i have an extra from a kenmore which i understand is made by whirlpool, The plugs are slightly different with one being a 4 pin with 3 males and a female and the other being a 4 pin all female. Can somebody please tell me which wires to splice together (solder and heat shrink ?) I understand that there are plugs avail but i simply can't afford to buy one. Thanks in advance.
I do not know if I can help but if you provide the model number of the fridge and the part number of the ice maker I may be able to find wiring diagrams for you. |
THIS FORUM IS DEAD!!!!!!! |
Thanks denman. The re fridge model # is MRS22WNGW6
The ice maker is an older unit. Here are the numbers that i found, I am unsure which is the model # IM #S 106 626636 The other number is LR 5810 or possibly LR 5010 (My poor old eyes aren't what they used to be) Manufacture date is 08-23-95
I wasn't able to make anything out on the diagrams as i don't see well. Is it possible for you to call me?
