mech
#1 Posted : Saturday, November 29, 2014 11:20:22 AM(UTC)
mech
Cooling fan stops runninng about 30 minutes after oven bake start.
Cancel oven let it cool.
Start oven again (325 degrees) fan runs again for about 30 minutes then quits.
Is there a thermal cut-off in circuit that would affect tge fan ?
#2 Posted : Sunday, November 30, 2014 2:12:12 AM(UTC)
Parts for KitchenAid KEBI141DBL11 Oven - AppliancePartsPros.com
There is no separate thermal cut-off unless they have added one and not bothered to update the wiring diagram. This does happen once in a while.
I would check the wiring connection to/from the board to the fan.
If OK then I would replace the fan.
It could be thermally protected internally.
Also could be that a winding wire is broken and it opens when it gets hot and closes when the motor cools down.
File Attachment(s):
KEBI141.pdf (307kb) downloaded 2 time(s).
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
GE Profile Wall Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Vinko 11/15/2013 9:41:11 AM(UTC)
oven cooling fan will not shut off (Oven Repair (including Ranges and Cooktops))
by wils-wife 4/26/2011 9:55:00 AM(UTC)
oven cooling fan (Oven Repair (including Ranges and Cooktops))
by larryp243 8/11/2010 10:22:10 AM(UTC)
Whirlpool Double Oven Cooling Fan Always On (Oven Repair (including Ranges and Cooktops))
by madisonpthree 1/6/2009 6:53:48 PM(UTC)
