While removing the igniter i found what seems to be the fan blade of the cooling fan , but i can't figure out how to find the motor to make sure it came from our oven or not . does this oven have to have it? if so. how do i get to the thing to replace it ?
Originally Posted by: larryp243  While removing the igniter i found what seems to be the fan blade of the cooling fan , but i can't figure out how to find the motor to make sure it came from our oven or not . does this oven have to have it? if so. how do i get to the thing to replace it ? Larry, I'd be a bit surprised, but it's a possibility. The cooling/circulation fan is located on the back of the oven, I don't think you can access it from the front, but you could double check me and try. You'd have to remove the control panel, and if possible slip the fan back onto the shaft of the motor. Dab a spot of contact cement or silicone sealer, in the shaft opening on the fan before you install it. :)
