AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
electric heat element glowing with dyer off and door open
during use chassis was extremely hot. cleaned vent, seemed to be ok for a few weeks. first load of the day opened door and saw element was glowing. found coil was touching the mounting bracket and bent it back in place. seems to work ok, thermostat appears to cycle normally, drum turns, vent blower works. still worried coil may heat up spontaneously ??
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  model is Kenmore 70 series. don't know if timer was in off position
Need a model number.
With just a series number I cannot find a wiring diagram. It is a Kenmore so their model numbers are usually 3 numbers, a period and then an additional 8 numbers |
Dryer Repair
