sonia0865
#1 Posted : 10 years ago
sonia0865
I was using my stove one day and suddenly the all burners stopped working. The oven also stopped working. I checked the breakers and power is not problem. When I turn burner knobs the LCD screen/control selector lights up and allows me to choose functions (bake, temperature, clock, etc), but stove AND/OR oven does not come on. I am a female with little attitude for repairing appliances without instructions.
Any help with troubleshooting this problem is appreciated.
#2 Posted : 10 years ago
A model number may help others help you.
Find your model number - AppliancePartsPros.com
If this is an electric stove then a power problem is at te top of the list as possible causes.
The oven light and control board/timer uses half the line (120 volts) but the elements all require the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
