Experienced a spike in electricity from a neighborhood transformer that caused the clock timer control board to burn out. After replacing this ($$) part, have thrown the breaker back on and the only working part on the oven is the lightbulb! My question is; what additional part should I investigate next?
Any additional help would be appreciated
Here are your parts Parts for Frigidaire PLEB30T8CCB Oven - AppliancePartsPros.comLooks like the oven lamps work off of L2 to Neutral. The control board etc work of of L1 to Neutral so I would start by checking the power, perhaps you have lost the L1 side of the line. The below is for a range and if your unit is hard wired then there will not be a wall receptacle so the checks will be a littke different. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
Denman Thank you! Pulled the breaker and worked my way back through the wiring as you had suggested. Problem was on the L1 side as you had thought. Thank you my friend, oven works fine due to your expertise.
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
