Blue49ers
#1 Posted : Friday, November 14, 2014 7:14:36 AM(UTC)
Blue49ers
I notice a while back that no matter what temp I set the dryer on, it always seemed to run on cotton/hot. This morning, the dryer just ran and ran (the timer dial didn't move), and the dryer never got hot. I tried switching from timed dry to manual setting, but still no heat nor shut off. Thermostat? Timer?
#2 Posted : Saturday, November 15, 2014 3:41:47 AM(UTC)
Here are your parts.
Parts for Kenmore Dryer 11066752500 - AppliancePartsPros.com
[COLOR="Blue"]I tried switching from timed dry to manual setting,[/COLOR]
Not sure I understand the above as I thought manual was timed dry.
I do not have an operators manual for this unit so I do not know what changes between these settings.
[COLOR="Blue"]but still no heat nor shut off. Thermostat? Timer[/COLOR]
I think the first thing to check is the power.
On this unit the heater and the timer motor work off of 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
[COLOR="Blue"]I notice a while back that no matter what temp I set the dryer on, it always seemed to run on cotton/hot.[/COLOR]
This may or may not be related to your current problem and will still need repairing.
Not sure what "cotton/hot" means.
Can only get heat on a cotton setting?
Always runs hot like the cotton setting no matter what setting it is on?
If it is the latter then check the heating coil.
Could be it is grounded in such a way that the operating thermostat cannot regulate it.
Unplug the unit and both heater wires.
Measure across the heater, they are usually in the 8 to 12 ohm range.
Now measure from each heater connector to it's case, both should be infinite ohms.
If not the element is grounded and the heater should be replaced.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
