wetlabs
#1 Posted : Friday, November 14, 2014 12:18:52 PM(UTC)
wetlabs
Dryer operates normally for five to seven minutes then shuts off. Restarts immediately as soon as the start botton is pushed. Will run for five to seven minutes and it turns off again. Replaced the control board, problem persists.
fairbank56
#2 Posted : Friday, November 14, 2014 12:44:08 PM(UTC)
fairbank56
Groups: Expert
Does it do the same when set to air fluff?
Eric
wetlabs
#3 Posted : Friday, November 14, 2014 12:48:21 PM(UTC)
wetlabs
I didn't try it on any other settings. In hindsight I suppose that would have told me something. I'll put it back together on Monday and check it out.
Dryer Stops After 5 Minutes (Dryer Repair)
by Rob S 11/8/2010 9:44:37 AM(UTC)
Dryer stops after 5 minutes, restarts fine (Dryer Repair)
by Hydrophilia 11/1/2009 8:25:35 AM(UTC)
