So the plastic tab that holds the pin/spring (right side) of the ice chute flap/door is broken. Problem is, it appears to be part of the main housing of the dispenser and I can find every part for the dispenser except the housing. What do?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Exactly my issue. After more digging it seems that not only is the part # not available, it considered a not serviceable part. I was able to find an ice chute door kit with an extra aluminum bracket to replace the broken plastic tab of the main housing. Whirlpool 8201756 Broken Tab Ice Door Kit - AppliancePartsPros.com
