ccollinswestdyke
#1 Posted : 10 years ago
ccollinswestdyke
my kenmore 80 series is having an agitation problem. the clothes seem to gather around the bottom of the agitator. it is spinning/filling/draining properly. the dog agits were replaced last year and look fine. when the washer is empty the top of the agitator spins freely clockwise and when i turn it counterclockwise the top "catches" and eventually spins freely with the bottom. any idea what the issue could be? tia!:)
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
Run a low level wash cycle with no clothes. Does the bottom part of the agitator go back and forth normally? If it's only going in one direction, then it's a bad transmission. If it's barely moving at all, pull the agitator and check for stripped splines up inside the agitator.
Eric
ccollinswestdyke
#3 Posted : 10 years ago
ccollinswestdyke
Thank you for your response. It looks like it's only going in one direction. :(
fairbank56
#4 Posted : 10 years ago
fairbank56
Groups: Expert
