ccollinswestdyke
#1 Posted : Monday, November 10, 2014 6:47:16 AM(UTC)
ccollinswestdyke
my kenmore 80 series is having an agitation problem. the clothes seem to gather around the bottom of the agitator. it is spinning/filling/draining properly. the dog agits were replaced last year and look fine. when the washer is empty the top of the agitator spins freely clockwise and when i turn it counterclockwise the top "catches" and eventually spins freely with the bottom. any idea what the issue could be? tia!:)
fairbank56
#2 Posted : Monday, November 10, 2014 10:42:07 AM(UTC)
fairbank56
Groups: Expert
Run a low level wash cycle with no clothes. Does the bottom part of the agitator go back and forth normally? If it's only going in one direction, then it's a bad transmission. If it's barely moving at all, pull the agitator and check for stripped splines up inside the agitator.
Eric
ccollinswestdyke
#3 Posted : Tuesday, November 11, 2014 1:38:35 PM(UTC)
ccollinswestdyke
Thank you for your response. It looks like it's only going in one direction. :(
fairbank56
#4 Posted : Tuesday, November 11, 2014 1:58:08 PM(UTC)
fairbank56
Groups: Expert
Guest (4)
