UPHOUSE
#1 Posted : 10 years ago
UPHOUSE
Could use some guidance. I am working on a Jenn-Air Model DW711B dishwasher pump & motor issue. This was due to a seal shaft water leak on the "D" shaft, which, consequently, rusted the solenoid bracket and pull solenoid, thus making the pull solenoid noisy. I replaced the shaft seal washer, "D" shaft "E" clips, solenoid bracket, assorted screws and the pull solenoid. When replacing the seal shaft I moved the "D" bracket to far and it disconnected the lifter from the drain flapper flapper assembly and flapper spring. Since I do not have, and was not able to locate in my area, or on line, a service manual for this machine, I had to go by a parts schematic that I received on line from Jenn-Air.
Consequently, I wasn't sure on the reinstallation of all of these parts. Since the plastic lifter can only be installed one way on the "D" shaft, it is believed that the flapper spring arm goes between the two prongs on the lifter. After completing the assembly as described above, I now have a situation where the dishwasher will not drain. The pull solenoid seems to work as designed, but when it goes into a drain cycle, it will not drain. Any suggestions, thoughts, recommendations, or a copy of a service manual for this repair would be appreciated. UPHOUSE
#2 Posted : 10 years ago
I can at least help when it comes to a manual.
Below is a link to one.
Not a great copy but the best I could do.
Unclick the "Use our download manager" and then use the grey button to download the manual.
Otherwise the site may pout software onto your computer that you do not want.
http://www.datafilehost.com/d/266748f5
UPHOUSE
#3 Posted : 10 years ago
UPHOUSE
I appreciated the reply and tryed downloading the manual from Denman regarding my issue, but was unable to do same due to damaged download file.
#4 Posted : 10 years ago
I just tried it and it downloaded OK for me though the site seemed slower than usual.
Also it said it failed in my downloads area but opened when I clicked on the .pdf file.
UPHOUSE
#5 Posted : 10 years ago
UPHOUSE
Tryed answering Denman back but I am getting a "Post rejected because of a score of 20: 20 rejection set to: 20". What does this mean? UPHOUSE
#6 Posted : 10 years ago
Perhaps the following will help.
http://forum.appliancepartspros...0182-post-rejection.html
Try changing your verbiage.
The site used to get a lot of spam so they have had to go heavy on the spam filter.
UPHOUSE
#7 Posted : 10 years ago
UPHOUSE
Tryed downloading again. Error message states file damaged. Norton Security blocked. Any other thoughts or ideas? UPHOUSE
#8 Posted : 10 years ago
Not sure how to get around this.
I do not use Norton Antivirus.
Also I do not know if you use it or if the web site is using it.
If you are using it you may have to shut it off to be able to download the manual. Then turn it back on as soon as you have it. Be sure to un-click the use our download manager on the site.
If you are not using it then you are either getting a false positive or there is a virus on your computer.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
High-pitched noise with LG dishwasher (Dishwasher Repair)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 11 months ago
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 12 months ago
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 12 months ago
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace about a year ago
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr about a year ago
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest about a year ago
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
