I have a Whirlpool Super Capacity Electric 465 range/oven. The surface burner indicator light is always on even when all burner dials are off. Also the left front burner is erratic. Are these interconnected? I know how to use a multimeter but not where to get started. Any ideas?
A model number may help others help you. Find your model number - AppliancePartsPros.comThe problem is most likely one of the infinite switches. Often each infinite switch has a switch that turns on the light. They are wired in parallel so one of them is probably always closed. Need a model number to find a wiring diagram so you can find it using your meter. |
THIS FORUM IS DEAD!!!!!!! |
