panel not working at all I have a Whirlpool Gold Accubake System Slide-in Range. The only thing that works on the control panel is the clock. It says PF and the time. I can't adjust the time. I can't turn anything on/off...
PF is that it has detected a power failure.
Press the stop/clear button to reset the fault.
Then you can reset the time and use the oven
None of the buttons work. I can't press stop/clear, start, bake, temp or anything. It says PF (power failure) because I flipped the breaker hoping to reset the oven to get it to work but that didn't help. I don't know if it's just the panel gone bad or if I should replace the whole oven. Is 10 years old for an oven?
