gfrazzle
#1 Posted : Tuesday, October 21, 2014 7:06:54 AM(UTC)
gfrazzle
Freezer section works fine, refrig too cold- temp set on 40, actual temp is 5 and changing setting has no effect.
#2 Posted : Tuesday, October 21, 2014 8:58:44 AM(UTC)
Parts for GSC25C6EYY - AppliancePartsPros.com
See the attachment for the tech sheet
Could be a problem with the diffuser (top in section 02 of the parts item 4).
In the tech sheet they call it an air baffle.
Looks like it used to come as a number of pieces but is now only available as an assembly.
Try running the diagnostics to see if it opens and closes.
File Attachment(s):
GSC25.pdf (680kb) downloaded 11 time(s).
gfrazzle
#3 Posted : Tuesday, October 21, 2014 10:09:34 AM(UTC)
gfrazzle
Thanks Denman! I 'll try the diagnostics.
Guest (4)
