2 Pages12>
cooldad52
#1 Posted : Wednesday, April 22, 2009 3:04:12 AM(UTC)
cooldad52
Rank:: Member
Please Help,i Changed The Bake Element, The Oven Sensor And Still Does Not Heat To Right Temperature, Please Help
cooldad52
#2 Posted : Wednesday, April 22, 2009 11:11:13 AM(UTC)
cooldad52
Rank:: Member
is there any help for me with my stove, can't get right temperature
#3 Posted : Wednesday, April 22, 2009 4:14:28 PM(UTC)
What is the difference between the set and the real temperatures?
You have to place the oven thermometer in the middle of the oven and open the oven door about 10 minutes after it got preheated.
cooldad52
#4 Posted : Tuesday, April 28, 2009 12:20:55 PM(UTC)
cooldad52
Rank:: Member
Gene, I placed the oven thermometer in the middle of oven and open the oven door after 15 minutes and no luck. I set the oven to 350 wait till it beeps then wait 15 minutes and the oven thermometer reads 150, I still don't what it could be. cooldad52
#5 Posted : Wednesday, April 29, 2009 12:39:57 PM(UTC)
Pull the range out of the wall, remove the rear panel and check the wires to the heating element(s). If there is nothing wrong then replace the relay board (#14 on the diagram).
- The part number for the relay board is AP4101944
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 6898VRV | AppliancePartsPros.com
cooldad52
#6 Posted : Wednesday, April 29, 2009 4:23:10 PM(UTC)
cooldad52
Rank:: Member
Gene, Where is the relay board located, under the glass top or in the back of oven,and it is easy to changed. Thank you cooldad52
#7 Posted : Wednesday, April 29, 2009 6:04:09 PM(UTC)
Most likely it's on the back. You will find it by tracing the wires from the heating elements. I do not think this part is too difficult to replace yourself.
cooldad52
#8 Posted : Tuesday, May 12, 2009 8:32:06 AM(UTC)
cooldad52
Rank:: Member
Gene,I replaced the relay board and still no luck,when you start the oven it starts off at 300 and it beeps at 400. I had it on for 4hrs and it started at 400 and after 4hrs it read 200 it won't hold the temperature i don't what else it could be. Help cooldad52
#9 Posted : Tuesday, May 12, 2009 11:31:36 AM(UTC)
In such situation the only part which can be suspected is the control board aka a clock.
- The part number for the clock is AP382950
You have to talk to the Appliance Parts Pros team about the part ETA. If this part is no longer available, you can try to rebuild the old part through PCBR.BIZ
brynababy
#10 Posted : Tuesday, September 8, 2009 1:34:35 PM(UTC)
brynababy
Do you know Frigidaire Stoves? Our oven is giving us the same problem that you responded to- the flame goes on when you turn the oven on, but the temperature doesn't rise. Thank you.
Joe Weiss
2 Pages12>
