Please Help,i Changed The Bake Element, The Oven Sensor And Still Does Not Heat To Right Temperature, Please Help
is there any help for me with my stove, can't get right temperature
What is the difference between the set and the real temperatures?
You have to place the oven thermometer in the middle of the oven and open the oven door about 10 minutes after it got preheated.
Gene, I placed the oven thermometer in the middle of oven and open the oven door after 15 minutes and no luck. I set the oven to 350 wait till it beeps then wait 15 minutes and the oven thermometer reads 150, I still don't what it could be. cooldad52
Gene, Where is the relay board located, under the glass top or in the back of oven,and it is easy to changed. Thank you cooldad52
Most likely it's on the back. You will find it by tracing the wires from the heating elements. I do not think this part is too difficult to replace yourself.
Gene,I replaced the relay board and still no luck,when you start the oven it starts off at 300 and it beeps at 400. I had it on for 4hrs and it started at 400 and after 4hrs it read 200 it won't hold the temperature i don't what else it could be. Help cooldad52
In such situation the only part which can be suspected is the control board aka a clock. - The part number for the clock is AP382950You have to talk to the Appliance Parts Pros team about the part ETA. If this part is no longer available, you can try to rebuild the old part through PCBR.BIZ Gene.
Originally Posted by: Gene  Do you know Frigidaire Stoves? Our oven is giving us the same problem that you responded to- the flame goes on when you turn the oven on, but the temperature doesn't rise. Thank you. Joe Weiss
