zombie242
#1 Posted : Wednesday, October 15, 2014 5:09:08 PM(UTC)
zombie242
Hello
My oven is glass top electric. My display will only turn on if my oven burner knobs are turned on? I cannot get anything to work but just a few weeks ago it did this very same thing but everything would work as long as I turned the knob on. Any help would be appreciated
#2 Posted : Thursday, October 16, 2014 2:22:42 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
Sounds like a power problem.
Perhaps you have lost half the line voltage (L1 usually).
Then when you turn on a stove top element L2 voltage feed through the control and it then powers the control board.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
zombie242
#3 Posted : Monday, October 20, 2014 12:39:44 PM(UTC)
zombie242
Thank you so much you were SPOT on! Ended up being a Burned out circuit breaker. $18 from menards and you saved me a 150 dollar service call. Honestly I appreciate the help:)
#4 Posted : Monday, October 20, 2014 11:56:49 PM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Guest (6)
