AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer stops after a few minutes on sensor cycle
Dryer starts and heats on moisture sensor cycle but stops after 5 minutes. Runs to completion on timed cycle without problem. Exhaust port removed and no clog obvious.
Groups: Expert
The dryer stops completely after several minutes if running on the moisture sensor setting. However, it doesn't stop when on the timed setting. Do you still think the timer is the problem?
Groups: Expert
Dryer Repair
