wxman
#1 Posted : Sunday, October 5, 2014 10:19:26 AM(UTC)
wxman
Dryer starts and heats on moisture sensor cycle but stops after 5 minutes. Runs to completion on timed cycle without problem. Exhaust port removed and no clog obvious.
fairbank56
#2 Posted : Sunday, October 5, 2014 3:50:21 PM(UTC)
fairbank56
Groups: Expert
If your saying the dryer stops heating or running altogether, the timer is faulty. If your saying the timer stops advancing, that is something else.
Whirlpool 3976576 Timer - AppliancePartsPros.com
Eric
wxman
#3 Posted : Sunday, October 5, 2014 4:32:56 PM(UTC)
wxman
The dryer stops completely after several minutes if running on the moisture sensor setting. However, it doesn't stop when on the timed setting. Do you still think the timer is the problem?
fairbank56
#4 Posted : Monday, October 6, 2014 11:56:13 AM(UTC)
fairbank56
Groups: Expert
Yes, faulty timer.
Eric
